Scott91370
- Apr 2, 2018
- Burleson, Tx
- Scott
- Sierra1500
Issue started out of the blue. We would start the truck every couple of days just to keep fluids moving - it has yet to be driven since it's not done being built. Started fine one day then the next just a click from the starter. Nothing changed from the day that it work to the next day. Went out today to troubleshoot
1) Pulled starter - solenoid activates and motor spins with 12v applied. Tested second starter, same results.
2) +12v wire from battery to starter tight.
3) There is a 2nd wire from the starter where the battery wire connects that goes through the harness into the cab of the truck.
4) Ignition wire from cab to start is tight.
5) Ground wire from battery goes to alternator bracket and truck frame. From same bolt to body. There is now a ground wire from the passenger head to the firewall.
If I turn the key to start and hold it for more than a couple of seconds the solenoid clicks then the ground wire gets HOT and smoke from the starter. Happens with both starters.
I am at a total loss and would appreciate any input you have.
