Starter install shim question.
cursh
phoenix AZ
ben
Silverado Suburban r20
Hey, I’ve got an 88 square body burb. 454 rwd and I just replaced the starter.
Yesterday it started right up. Today, this mess: (see video)
This is what the last starter sorta sounded like. What gives?
Old Guy Bill
KY
Bill
When shimming a starter I use an 1/8” drill bit between the mesh of the ring gear and starter gear…
fast 99
Spokane, Washington
Noise is irregular. If a new starter is installed on a bad ring gear it will need another new starter and a ring. They both need to be replaced at the same time or starter will be noisy.
A paper clip will also work to check clearance but can't ever remember checking that. Most times accessibility is a problem.
cursh
phoenix AZ
ben
I’ll use the 1/8” bit. I think i can manage to access what I need to check with that method. It’s too tight down there to engage the gear and check with a paper clip. I’ll also take a look at the ring gear(that’s the thing the starter engages, yeah?). It looked fine to me when I was installing the starter, but I guess I can only see about a third of it at a time.
seanhatesregister
