MrMarty51
- Oct 25, 2012
- Eastern Montana
- Martin
- K20
Also check if there is excess fuel in the oil.
Sometimes them mechanical fuel pumps will go bad and pump a lot of fuel into the crankcase,thinning the oil and not lubricating the internals as it should,thus,creating excess heat and low oil pressure.
If this condition does,in fact exist,then,it will create excessive wear on bearings,camlobes,cylinders,etc.sometimes even comes off as white smoke out the tail pipe.
Pressure/vacuum guage will tell You what You needs to know about Your fuel pump,that and a "Flow" test.
I`m thinking,but it seems like the avereage fuel pressure should be around 8 PSI,but,it has been a very long time and I do`n rememers like I used toooooo.
