Start issue Wednesday
84GMCSierra
Central Arizona
C2500
The bracket goes on the top thru bolt on the starter, the one that looks like a stud with a nut and washer. I haven't seen one of these intact in years, so all I can say is to mount it to that bolt/stud on the starter, hold it in place (or bolt it up to the mount so you don't have to hold it, I know they're heavy!)and see where the other end lands. The bracket's curvature should d follow the side of the block.
I'm not sure the 400 I have, still has a starter on it, and that's the only small block I have that's old enough to have this bracket. These were a great idea, but many got tossed when the starter was changed, because "it's in the way, what do we need this for". GM wouldn't have put it there if it wasn't needed.
Unfortunately it looks like I don't have anywhere to mount it to the block. Apparently aftermarket blocks don't have a mount point on them for a starter brace.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Well that just sucks....
Is it close enough to the dipstick tube mount, to run a piece of bar stock between the holes? That's better than nothing.
84GMCSierra
Central Arizona
C2500
I was thinking the same thing. I'll look at that this weekend when I'm off work.
78 squarebody
