A good friend of mine used a harness from PSI for his conversion. It's really nice and works flawlessly.
Painless makes a good harness, the summit catalog has a very generic description call painless before ordering.
PSI has a good rep for their products, beware of other online shops there is quite a few companies that will rip you off.
it isnt all that hard to unfunk the stock harness and use the factory fuse block, I had mine like that for a few years but wanted to clean it up so I recently installed a Painless harness. 1 thing I did notice about the painless harness is it seems it was designed for the PCM to mount under the dash and I probably should have done that, but I didnt and it works great.
Of course the chinese harness is cheap af. Surprised it’s that much cheaper though.I ordered mine on alibaba. It’s the same harness many US companies sell. My harness was made to order the way I specified for $270 all in delivered to my door 8 days after I placed the order. The quality of the harness and connectors is OEM in my opinion. I’ve had no problems with it at all.
Mine came with an instruction book. It has a diagram showing what every connector is for and has all the wire colors and their destinations listed. Make it really easy to troubleshoot if needed. The people I ordered mine from were extremely helpful and responded quick.Did the wires in those kits come labeled? I checked into those on ebay, and the sellers will not respond to my question about the wires being labeled. I noticed a set of wires rolled up with no connectors and was wondering about them.
This is the seller I bought from. Just submit an inquiry and tell them what year motor and size, what transmission, what style injector plugs you need and they will tell you the cost. Mine showed up 8 days after I ordered it.Did the wires in those kits come labeled? I checked into those on ebay, and the sellers will not respond to my question about the wires being labeled. I noticed a set of wires rolled up with no connectors and was wondering about them.
