Squarebody Cabs
davbell22602
Bunker Hill, WV
I Dont
Have
One
After removing the doors etc. from the cab. Are there sections that are spot welded together that person could take apart by using a spot weld drill bit?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Yes. If you really wanted, you could dissasemble the entire cab, but you would need a LOT of spotweld bits for that many welds. There are at least 30 spot welds along the back window pinch seam alone...
I've thought of removing the blower housing area to fix the rust behind it, but some of the spot welds are at bad angles to get a bit into, due to other sheet metal.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Are the dashes spot welded too or just a bolt on?
davbell22602
Bunker Hill, WV
I Dont
Have
One
Ok, Thanks. I just wanted know. I'm getting to experience this on a non square vehicle here soon.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Does anybody have a diagram of spot welded seams on squarebody cab?
willfill
