Square Body C3500 steering shaft swap
dd1990
Ventura CA
Suburban 1500
Havened seen anyone mention this here. I just swapped out my old rag joint steering shaft for a C3500 steering shaft. C3500 steering shaft has a u-joint connection at the gear box. Safer than the XJ swap since the connection at the column is with a normal cross bolt compared to the clamp style of the XJ steering shaft. Steering play has been drastically reduced with the C3500 shaft.
Camar068
10 yrs Air Force
Good to know. Thats why I drilled mine for that cross bolt. Might wanna post this info in the intermediate shaft post as well. If it's there already, it'll be a reminder.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
What year c3500 did you use for application?
squaredeal91
Greg bush
1991 SB
I chose same year as my suburban 1990
I wonder why my 1991 GMC 2wd 3500 doesn't have one? Thats what i want it for. Must have been replaced once before I got it.
dd1990
Ventura CA
Suburban 1500
I'm not exactly sure but I believe only the HD 3500s got them, over a certain gross weight
dd1990
Ventura CA
Suburban 1500
Part numbers below:
Gm shaft Part #26015779
GM bolt part #11610555
Dorman shaft #425-177
2manysquares2care
