hinkv10
- Nov 8, 2012
- ct
- craig
- v10
Hi, after a 6 month hiatus I have started working on the old girl again. Its a 87 V10 that's been converted to carb. Stock suspension 31's but with a Rugby dump kit and a factory bed. The bed and frame was reinforced but besides that its pretty much stock.
Last summer I por'd the frame and ended up replacing the shocks and springs in the rear at the same time. I went to General Spring in KC and ordered rear springs; 2150 lb capacity 5(4/1) leaves 52" spring. Is that a good spring for a toy work truck? I load it pretty heavy with firewood from time to time and am going to start driving it longer distances but it is pretty much a local ride. I didn't replace the front springs because the bushings weren't as shot as the rear but the truck is almost 30 years old now..... Should I replace those as well? and with the same capacity? I really don't know much about springs and trying to get a little insight. Thanks in advance
