Speedometer off
Red Rex
Middle Ga
K 1500 4 WD shortbed
My speedometer reads 5 mph faster than my gps.
208c transfer case original equipment
Th350 transmission replaced 700r4
3.08 gears original equipment
30 inch tires
I have changed the speedometer with a junkyard part
No adapter on the transfer case. It has a black plastic gear in the housing.
How can I tell what gear in the housing I need and where might I get it or do I need to change the speedometer?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
30 inch tires
You dont need to change the speedometer. You need to change the gears.
here's a link to a similar post that might help https://www.gmsquarebody.com/threads/np208-speedo-driven-gear-needed.20778/
Red Rex
Middle Ga
Appreciate the information and post!
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
What gears did you end up going with? My truck is a mix of 4.3L V6 and CUCV. I don't know which of the two my transfer case came out of. What I do know is the V6 should have come with 3.73 rear gears and my truck has 3.08 in the back. My speedometer reads about 35mph when I'm going over 50mph.
jlyon1006
