Speedometer help
327k10
PA
Chaz
First timer guys, and I'm young so if I mess up cut me a break. I got my 83 k10 327 four speed with 38 in tires, and when I drive the speedometer only goes to about 45. If I've done my homework the speedometer cable on that year is mechanical, and plugs into the transfer case, and is driven by a little gear that can be changed to compensate for the larger tires. So I'm asking is this info true, and where and what gear would I need to straighten the speedometer out. Thanks for your time guys.
327k10
PA
Chaz
Come'on guys I know someone has some input for me.
Stroked
Beloit, Kansas
Jared
Yes that is correct. Not sure which one you would need though. I would check with a local transmission shop.
327k10
PA
Chaz
Thanks that helps, so I'm not completely off track.
327k10
PA
Chaz
I've been on there, it's a little confusing, was hoping to run into someone with close to the same situation.
Stroked
Beloit, Kansas
Jared
Sorry I'm not much help. I've researched it a little, but I've never had big enough tires to throw my speedometer off enough to worry about.
327k10
PA
Chaz
Hey man it's cool, I'm new on here it's just nice socializing with ppl who love these old dogs as much as I do. I appreciate your help.
goodwrenchca
