speedo
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
this morning my speedo quit working. it worked started fluckuating (sp) then went to zero. what is the best way to see if its the speedo or the cable thats not functioning
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Unscrew the cable from the trans and put a cordless drill on it and run it kind of slow in reverse. Might need a helper to look at the speedo and see if it is working. If it is working then it may be the adapter box thingy if your truck has one. If it isn't working, try to pull the cable out. I cant remember if they go in at the trans or at the speedo. If they go in at the trans, pull it out till you find the end, it should be square on the end. If it is round or looks ravelled then the cable is broke. IF it is supposed to go in at the speedo (there's a brass stopper thing on it) and you pull at the trans end, if it comes out it is broke. If it dont come out, it still may have the square end broke off and the brass keeper is stopping the cable from coming out. Getting to the back of the speedo and the clip that holds the cable on is a real bitch, so you've been warned!! One other thing it could be if that all checks out is the plastic speedo gears in the tailshaft of your trans.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
ok ill give that a try when i left work it worked for a couple miles then stopped
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
87 might not have a speedo cable, instead it may just have a vss down at the trans tail housing. its held in with a 10mm bolt. Take that out first, and make sure that the gear is not broken, and the gear thats on the trans shaft too.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
87 might not have a speedo cable, instead it may just have a vss down at the trans tailmhousing. its held in with a 10mm bolt. Take that out first, and make sure that the gear is not broken, and the gear thats on the trans shaft too.
My 88 burb still has a speedo cable and vss is at the back of the speedometer.
Jims86
Patterson,Ca
5.7 TBI
hmmm....
I am getting p/n 8673299 for that truck.
Interesting
Jims86
Patterson,Ca
5.7 TBI
Wow...Im finding a bunch of wierd **** for speedos on that truck...mechanical and electronic!
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
its got a cable no electrical
Jims86
Patterson,Ca
5.7 TBI
Well, There ya go!
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
but it does have a sensor beside the cable
Guardian
Jeff
c 10
THe sensor should provide the feed to the ecm for reference.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
yes it does. my check engine lite comes on within 2-3 mins of driving
Guardian
Jeff
c 10
Did it make any noise before it quit?
Jims86
Patterson,Ca
5.7 TBI
Where isnyour VSS, is it down at the trans with the cable connected to it, or is it the optical one behind the speedo?
Gemini
