Speed Hut Speedometer Install....no signal error!
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
Hey Folks,
I just installed a set of Speed Hut gauges in my 1991 V1500 Suburban, 5.7 TBI, electrical speedo, 700R4, 241.
I have two (2) problems.
Problem #1:
I connected the input into the new speedo to the old pin 18 from the dash cluster plug....light blue/black stripe. I have tried both with chassis ground and without. When trying to program the speedometer I get a "No Signal" error on the speedo.
Anyone done this before? I think I need to keep the DRAC in the system for the ECM so I assumed that using the output of the DRAC like the factory speedo used was correct. I have a message to Speed Hut but have not heard back from them.
Any ideas?
Problem #2:
Are there any other places to connect the oil pressure gauge to? I know about the rear of the distributor but can't get my eyes or hands in there to add a "T" so I can use the old switched signal for the fuel pump operation. I figured I would leave it alone for fuel and go with another spot.
I hear there is a spot near the oil filter but I don't see it either. Anyone have a picture of that location? Somewhere I read that the port near the filter was not a really good place to use since something could happen in the engine and still have good pressure at that port. My old 1986 M1009 (surplus blazer) had a oil line to the radiator that could be tapped at the radiator but that was the 6.2 diesel and I am sure they are a good bit different?
Can I add a adapter at the oil filter and get a port there? Any other holes in the engine that would give me a good reading?
For those that like a picture:
Any ideas on this one?
Any help would be greatly appreciated.
I have no clue about the speedo signal.
But the oil pressure port will be directly above the filter, facing the side of the truck. If there is not a sender or switch there now, there will be a pipe plug.
You can get at the oil sender arrangement up by the distributor, but it's certainly a little uncomfortable to do it.
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
Thanks for the input on the Oil Pressure. I found it and installed it and it looks like it works fine. Yea!
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
I also figured out the speedo connection. I had to install a resistor between 12vdc and the speedo signal form the DRAC. Apparently it is called a "pull up" resistor and is needed but lost when I pulled the old cluster. I put in a 4.7K ohm resistor vs the 10K in this picture and it let me set it up and seems to be working pretty well.
Here is where I put the resistor on the DRAC instead of in the cluster....
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
Good info!
So this little gem of info is probably needed when installing any aftermarket speedo with a factory DRAC and VSS?
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
Probably so. The schematic showed my VSS output on C15 but in reality it was on C14. I suspect the difference in My 91 Suburban V1500 vs a 1985 pickup.
RogerioHR
