Source for Power Window door panels?
7900_Blazer
Francis
Blazer
I can't seem to find a supplier for power window door panels for a 1975 Blazer. - Manual windows all day long... but no power window door panels.
Would a 1977 door panel fit by chance?
Other options?
Any help is much appreicated!
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I don't think power windows were offered until 77, there was a change to the door shell that year too to accommodate the power window option but I'm not sure what exactly they changed. I don't know if the later model interior panels will fit the older doors. Someone on here should know.
Did you buy it with power windows already installed? If so, someone probably swapped the doors for newer ones with factory power windows.
Also... There's a company out there that makes power window switches that look like window cranks if you need to keep the factory looking panels in it.
^What he said. Power windows/locks didn't come out until '77, so there's no such thing as power '73-76 panels.
7900_Blazer
Francis
Blazer
@CalSgt - Thanks for the info.
When I bought this Blazer it was a literal rusted basket case.... but the previous owner gave me two door he picked up from a salvage yard - electric window doors. I'm very glad to know these are likely '77 doors... as I didn't know what the model range was. I can source power window door panels for a '77 - makes sense now why I couldn't for a '75
CalSgt
CA
Casey
I just got a set of 1989 suburban doors with power & it looks like my older door panels ('77-'80) from LMC truck will fit with no issues.
So if it's a '75 Blazer, it's a full top truck. Those '77-up doors will bolt on but won't work with the top. You'll have to cut the frames and modify to fit.
7900_Blazer
Francis
Blazer
The does are 'Blazer' doors... and they are 'power window factory doors'... so makes me think someone else already 'cut't them...
I'm going to order some '77 door panels and see how they fit...
Ahhh, that's good. Here's a couple pictures of the early vs late door, the later ones have all the holes around the edges that the early ones don't have. For mounting the later style panel. If yours has that, you'll be good.
73-76
77-87
dwolff13
phoenix az
dan
k-10
I got mine from Holley Classic truck. they are much nicer than the LMC ones, ...
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
adding p/w and p/d/lock is easy in any year model! :)
ESONE
