buddy350
- Sep 13, 2017
- El Paso,TX
- Buddy
- 1973 k20
- Suburban
Not sure if these are special or not, “big hub”.
anyhow
When I get some more time off work I’m planning on hitting them up with some pool sand then hose them down with a bit to f black rattle can.
At that point pull the diff covers and have a look as to what ratio is labeled in the ring gear.
The pinion seal on the rear diff is already leaking a bit so that will have to be addressed as well.
Lots of work to do and plenty of motivation just lacking the time off of work.
anyhow
