Sniper efi a/c wiring
cabardi169
Sulphur, La
Joseph
Sierra
So with the sniper efi there is 2 wires that you have to connect for a/c, does anyone know where to wire those 2 wires to?
Chuckd84
Sedley Va
Chuck
Silverado K20
Im assuming your in the 10 pin connector, in the yellow
cabardi169
Sulphur, La
Joseph
Sierra
That’s correct.. A&E are the ones I need help with.
Chuckd84
Sedley Va
Chuck
Silverado K20
“A” is a ground input telling the ecm to increase the iac to compensate for the compressor load. You would need to use the 12v supply to the compressor clutch to close a 5 pin relay. Then supply a ground to pin 30 and connect lead “A” to pin 87.
Chuckd84
Sedley Va
Chuck
Silverado K20
“E” is used for engines reaching high enough rpms that compressor clutch need to release to prevent damage. Im pretty sure thats above 6,500 rpm.
cabardi169
Sulphur, La
Joseph
Sierra
Appreciate your help man! I got it wired up, but still not finished with the install.
zapattack
