Smog Regulations
Mason Lawley
Reno, Nevada
Mason
Is there a website of sorts that will tell what each state's smog requirements are?
Unfortunately, my C20 is gonna be registered in California and I am curious what the requirements are. I've ordered all the parts for a proper tune-up, but I'm not sure about whether to pull the trigger on headers, intake manifold, etc.
And I've also seen a lot of debate on the "charcoal canisters" for ventilation/filtration. What's anyone's take on deleting those?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
It will need the equipment it came with from the factory. There are two standards, "49 State compliant" or "49 State Plus California". Your under-hood emissions sticker (probably long gone) determines which it is. There's no way to look it up online, way too many variables, so your only option is to contact the California Air Resources Board in the area you move to and they will tell you what it needs. Regarding the charcoal canister, all vehicles came with them and they are required in order to pass emissions testing.
If your truck has been gutted/modified to a large degree, be prepared to spend some serious money on it bringing it back into compliance. In some cases, it makes more sense to leave yours behind and buy one that's already compliant in California.
It will need the equipment it came with from the factory. There are two standards, "49 State compliant" or "49 State PLUS California". Your under-hood emissions sticker (probably long gone) determines which it is. There's no way to look it up online, way to many variables, so your only option is to contact the California Air Resources Board in the area you move to and they will tell you what it needs. Regarding the charcoal canister, all vehicles came with them from GM and they are required in order to pass emissions testing.
That is not necessarily true. My 1980 K25 with federal emissions had no EGR, No air pump, and no charcoal canister from the factory. It was the 8600 GVW option and therefore was heavy duty emissions and didn't have any of that smog junk.
First of all... do you have the SPID label in the glovebox still? Is the emissions tag still on the air cleaner or core support? PICS!!!!??!?!?!?!
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I guess it's possible yours didn't have a charcoal canister originally. It's also possible that many were removed before the current owners ever saw the vehicle. I'm writing from memory and it's been forty years since I worked as a Cali smog tech, but I don't recall testing any that didn't have a charcoal canister. Those were kind of a given, like pcv systems, everybody had one. But that points right back to my statement that there are so many variables that you have to consult the CARB. They have the final say, not a bunch of guys on the internet.
Craig 85
Nashville, TN
454/TH-400/NP205
Contact a smog referee, they can give you the specs for your truck. Unfortunately, in California, if you don't have proof it was a Federal truck to begin with, they will make you meet California equipment requirements. There is very little you can modify unless the part has an EO Number or it is a direct replacement part. Removal of anything that came with the truck is not allowed.
There are some legal headers and intakes. I had an issue with my last truck, a '79 K15. The intake warped and would not pass smog. I was able to add a Performer intake instead, but it had to be the EGR model. The intake did not have an EO Number, but had the same provisions for OEM equipment so it was allowed.
https://www.bar.ca.gov/Consumer/Referee_Program/
FYI here's all the crap on mine and it's an HD emissions truck that originally ran on leaded fuel!
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
acord
according to the 78 options manual for a 350 in a c20 see here and download for specs https://www.gmheritagecenter.com/do...its/Chevrolet-Trucks/1978-Chevrolet-Truck.pdf see pages 165-167.
california emissions PCV positive crankcase ventilation, ECS evap canister ,TRC throttle return control, CHA carbureted heated air (hot air off the exhaust heat stove), AIR air injection reaction smog pump.
if its federal emissions PVC, CCS basically gm jargon for carb calibration timing and CHA carbureted heated air heated air cleaner,
My 2 cents charcoal canisters dont hurt your performance keep it.
Raiderslim2003
California
Greg
K-10
6.2L
If anyone is looking for a Smog exempt square body, I have a 1984 K-10 Diesel. Never have to smog in California.
1984 Chevy K10 4X4
6.2L Diesel, No Smog In California
4 Speed Manual SM465
Perfect for a LS Swap and Never Have to Smog It!
***NO RUST, SOLID FLOORS, ROCKERS, ECT...
A/C
New drums, shoes, hardware and wheel cylinders on the rear brakes,
Bearings, pads and rotors on front
New master cylinder and distribution block
All 4 new shocks
New AC compressor, condenser and receiver/dryer with R134 conversion and pressure switch
Lift pump and fuel filter
Both fuel tanks are new with new senders,
New fuel tank switch and selector
Glow plugs replaced.
New carpet, seat cover, dash pad and headliner with sun visors,
Door hinges rebuilt
New grill and head light doors.
New radiator and fan
Rebuilt SM465 4 speed transmission with new clutch and flywheel and linkage.
**No Trades and I don't Need Help Selling.
$15,500.00 OBO
jlyon1006
