Slip yoke leak
Drswiger
US
Johnny
Center of the slip yoke leaking
Is there a problem using RTV in the center ? Or a better way?
Mofarmer
Missouri
Mark
Anxious to hear some responses my 86 c10 is doing the same thing!
yevgenievich
Place
Name
Year
Model
Size
There Is a seal inside tail housing on output shaft. Or replace with a yoke that is missing one spline and non vented to outside
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
You can rtv it, won't last long I'm sure. I just sucked it up and bought a new yoke.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Also have you ever done u-joints?
Drswiger
US
Johnny
Sounds like the RTV is temporary. I think I am going to try some JB weld and see how long it lasts. If it doesn’t work I will look for a yoke that doesn’t have the vent if I can. I have a press so I can replace the unjointed while I’m there. Just a PITA
Drswiger
US
Johnny
by the way, does anyone have a part number for a non vented yoke for 87 R10?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
there's an oring inside the end of the tube that's where the leak is. Easy fix , probably easer that trying to JB weld it.
Drswiger
US
Johnny
Where exactly? What tube?
Dave M
Banned
Australia
Dave
^ It would definetley be bad ! Here is an example of BAD
Joshua Keith
Memphis
Joshua
Don't JB Weld it dude...
:nono:
That would be bad.
:disgust:
Definitely not good?
:thumbsdown:
Uh oh lol What would be the difference in jb welding the weep hole vs getting a shaft without one?
Rusty Nail
Rusty
350sbc
If you plug the weep hole, that doesn't fix the leak.. It will continue to leak internally, no? Then what happens?
Reckon it was there for a reason.
You don't wonder why?
  • Like
Reactions: WFO
If you JB weld it, you are effectively sealing the space there. Which means that every time the shaft tries to slide out it will create a vacuum and every time the shaft tries to slide in, it will generate pressure inside that cavity. The BEST outcome of that is that it blows the JB weld right out the end and you get your leak coming back. The worst case is that the shaft doesn't want to slide and it pushes in on the output shaft of the trans and in on the pinion of the rear diff. That's going to be extra thrust load and premature wear on U-joints and thrust washers in both the transmission and rear end. Its just as much work(or actually probably less) to just pull the rear driveline, take the 4 bolts off for the rear trans housing, replace the output seal on the rear housing(because you are already there) and pop a new o-ring in the output shaft. It's probably a 1 hour job... tops. Then you will be right back to new, non-leaking, operation for about $20 and 1 hour of your time.
  • Like
Reactions: WFO
Papa Rosa
