Skyjacker Lift Spring Bushing Issue
Evil Crew Cab
Reno, NV
Steven
V30 CC SRW Conversion
454 TBI/4L80E/NP205/D60/Gen 2 14BFF
So around 6 months after installing the springs, the bushings are mauled....I used poly grease when installing the bushings and used it liberally! The front bushing on the driver side spring is already walking the entire spring back and forth over 1/2" when steering side to side as the drag link pushes and pulls the spindle.
Anyone else have issues like this?
Since Skyjacker decided to use a unique bushing size, I haven't been able to find a better bushing...does anyone know of an option to fix this?
Since I bought the springs at Summit, ill likely return them if I can't find a good solution, and go with a set of Nationals, Alcans or Deavers springs since I still have to get rid of the blocks in the rear in favor of springs as well...
hirschdalechevy
norcal
rich
k-30
I have skyjacker springs on three of my square's and have had no problem's , did you put the inner steel inserts in ?
Evil Crew Cab
Reno, NV
Steven
Of course I did... :)
cahillasher76
