Shop heater
JD Miller
Goober Idaho
JD
K20 silverado
What do you have for a shop heater?
I might do a electric shop heater, thought about a pellet stove, put just want "easy peesy" push button heat. I have a wood burning stove in the house that is plenty of work with firewood, stoken stokin a fire every morning
Anyone got a recommendation for a electric shop heater?
legopnuematic
Licensed Junk Dealer
MO
Spencer
How big is the space you want to heat and what do you have for insulation?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Pellet stoves aren’t that bad maintenance-wise either…We vacuum out the stove every bag and have never had an issue.
All depends on what you pay for electricity, gas, etc. We pay $0.32-0.56/kWh, so electricity would be way too expensive. Propane is ~$2/gallon when we fill our tank in July, but if we used it for heat we’d be filling in the winter too at $5/gallon. Pellets cost $6/bag and a bag will last about 2 days. Not as cheap as wood, but as you mentioned, much more convenient.
Hunter79764
Grand Prairie, TX
Suburban V20
I use Texas for my shop heater...
Jk, sort of. Not a huge need for it here, but I'm interested in adding a portable propane heater for mine next winter.
Gas heat is usually more cost efficient to run, electric heat is usually more install friendly, but both of those depend on your utility availability and cost. Radiant heat is a winner for intermittent heating needs (vs keeping it at a warm temperature constantly) since you are using the radiant heat to heat objects vs using typical heaters to heat air that then heats objects. Are you on Natural Gas service, or LPG tanks? Any idea your electric rates?
JD Miller
Goober Idaho
JD
K20 silverado
Need Electric heater
No
Natural gas here. House has 250 gal propane tank, and to far from shop. Propane is expensive. Summer $2.40 per gal summer, $2.70-2.80 winter price. $$$$ o_O
Electricity is cheapest . Either electric or pellet stove or wood stove for the shop. 30x40 ft insulated, 12ft- 16 ft high ceiling.
Hunter79764
Grand Prairie, TX
Suburban V20
I vote infrared electric if you use it intermittently. If you want to maintain a temperature for the entire day etc, you might actually look into a heat pump (you don't have to duct it, just have the "furnace" with a filter inlet and some sheetmetal scrap to direct the airflow where you are working). Bonus is that you'll have AC in the summer as well, and in mild weather, you can just run it as a fan.
Get creative with plastic sheeting and you can make a paint booth, using this as your air supply and exhausting out a controlled point on the other side. Find someone in the HVAC field and see if you can snag a used unit for cheap. Some infrared heater units might still be nice, especially at a workbench etc. Anyway, just some thoughts.
I put a heat pump in mine after just using a portable propane one for years. It was kind of a fathers day gift to myself. ~$600 and it keeps the shop ~64 degrees in the winter and 75-ish in the summer to conserve the energy usage. I installed it myself and most of them come precharged, so you just run the power feed, run the piping, pull a vacuum in the system using a standard vacuum pump you can rent from autozone for free, then open the valves and voila.
87scotty
Central il
Andrew
V20
5.7 for now
Boiler that heats my house, 300ft away the residual heat that comes off the boiler and magic heat in the stack keep the shop nice and toasty, 40degree day plus I open doors windows lol
87scotty
Central il
Andrew
V20
5.7 for now
Oops didn't wait long enough for it to load.
Chugalugg
Camp Verde, AZ (86322)
Chuck
I've had the wood stove, ceiling Reznor gas unit and now have the Lg Mini-split and love it. It wouldnt be right for everyone but its the best for me. Warm in the winter cool in the summer! Just keep the washable filter clean.
Doppleganger
OH-MI: Just like it sounds
My 'shop' is a 2-1/2 car garage...partially closed ceiling but no insulation. I have one of those small bullet heaters and a propane tank like you use with a grill. Will put me in a t-shirt in about 10min, but no matter how much I vent it, within an hour I'm shutting it off and leaving from fumes. Would do one of those wall mount parabolic heaters but my ceiling (< 8 ft) isn't tall enough.
When we get out of this zip code, I'm going with a barrel stove.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
i recently installed a mr cool mini split and I'm very happy with it. Keeps our 100 year old house upstairs warm and easy on the wallet. Our house is poorly insulated. Will be working on that next year. But it's tricky as there isnt a vapor barrier either so it may just be uninsulated in some areas forever.
86 C10 Shortbed
Ohio
Mark
5.3L
Modine 45,000BTU natural gas forced air furnace in my two car garage.
JUKA
