Shocks?
Steve-o81
Festus, MO
Steve
Hi, I don’t know a ton about shocks, but I pulled all 4 still good old Gabriel Gas Shocks off my 1981 Silverado. I likes them a lot but I don’t think Gabriel makes gas type shocks anymore. So I was considering Monroe as replacements but I don’t want the ride quality different from the Gabriel’s. Any advice? Thanks!
Danderson
Chatsworth GA
Doug
I've got Monroe's on my 1977 K10 and I like them a lot, but if you want Gabriel's then Rock Auto sells them.
Octane
Atlanta
Eddie
I recently put Monroe gas Magnums on my 77 K10 I think they're a great shock also. Also changed out the steering damper to a Monroe.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Just go with the best price. I'd recommend some KYB shocks as they should be in the same ballpark.
RCSB73
Josh
Check the travel first... I just got KYB replacement shocks and apparently the reason the last ones blew out is due to less than 1 inch of compression left at current ride height in the rear and about 1 1/2" up front... No lowering shackles, hangers or spindles but maybe at some point springs were removed in the rear and cut up front... No evidence of heating to lower either so I ordered stock ride shocks... Save yourself some money and time, check the travel and order accordingly...
charliesquarehed
