83kid
- Apr 13, 2014
- Massachusettes
- John
- k10
Hi,
So i an have 83 k10 with a 350 in it, 4 inch lift (Blocks in the rear, springs in the front), 33's, and recently have notcied a kinda bad shake
Before i explain, not u joints as far as i can tell, had them replaced about 3k miles ago, and driveshaft is wicked tight, it doesnt budge when you twist it
so, its not constant, it'll happen like half the time, not all the time, but it happens quite a bit.
Doesnt really matter the speed, doesnt do it in neutral if you just rev it, seems to do it anywhere from like 15-25 35-whatever, but probably does it from 15 up just havent had it happen going around 30 yet
Doesn't really happen when accelerating, happens most when cruising and sometimes more often decelerating.
The truck itself, and me feel a shaking motion, i cant tell if it shakes you up or down or if its going forward then backwards. But its like driving down a rockyish gravel road with ****** suspension, that kind of motion except its more slower, not a wicked fast vibration, but might be relative to when the tire spins, i cant tell as i havent been able to see it and know how fast the tires turn around.
Noticed today both front tires have more wear on the outsides than the inside, its sloped from like half tread gradually to nearly brand new tread
Never really looked at them for that before, bought the truck a few months ago with them on it, havent touched them
What could it be?
Thanks!
What could it be?
Thanks!
