Screwed up my 12 bolt
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Good, as long as you were able to get 0.005" - 0.015" backlash, good mesh pattern power and coast, and a little turning resistance on the pinion (24 in/lbs rotational torque is hard to gauge without an in/lb torque wrench) it should be fine. Be sure to change the gear oil after 500 miles and if you plan any long trips in that break-in period pull over after 100 miles or so and check that the diff isn't getting too hot. If it overheats it will push the oil out of the overflow.
1low4x4
Nick
I have an inch pound torque wrench but didn't use it. I just tightened to feel by spinning it by hand. I got about 0.012 backlash. didn't even use the paint cause we never did when I was growing up building racecars with stepdad.
The 500 mile oil change will be a good reason to install a big aluminum diff cover
Gilm
