ScottyB
- Aug 28, 2013
- Whatcom County, Washington
- Scott
- phantom
- 2 squirrels
Remember when I said I knew less than someone who knows enough to be dangerous? Here is where I prove it.
I have the goal of turning my '77 stock C-30 into a gas mizer. I understand that the 454 is known as a high torque engine. Keeping in mind that any towing I would do with this I could also do with my 4 cyl Ranger if I needed to, how would you rebuild a 454 to squeeze the milage out of it?
First thing I always hear is to ditch the carb for TBI or MPI. I see the logic there and I am thinking about the Holly Avenger EFI kit. The cam always comes up and I am told to put in a mild or RV cam. I understand what a cam does and how it works, but the magic behind the numbers is more voodoo that stumps me. With the cam, obviously goes the heads. If they don't match than you are just mixing expensive parts for the sake of spending money. Mild cam and matching heads sound like the way to go but I can't explain why in a way that makes me comfortable.
While I have the engine torn down, it is obvious that I would have the block cleaned and machined in prep for a rebuild. The cylinder bore and crank journals can't really be planned in advance as those are dependent on the condition of the block. This brings up a couple questions though that are related. First is pistons, flat, dished or domed? What is the difference? How does this affect Compression Ratio? I understand that the greater the ratio the better economy you will get. Also, at some point you will need to go to a higher grade gas. That is a trade off I am willing to make if the economy would be high enough to justify it.
Ignition, hotter is better as far as I understand. But at what point are you reaching the point of diminishing returns? This is not a race engine that is going to turn 6-8000 RPMs. This is a DD where the idea is to keep RPMs at a sensible level.
The discussion took place earlier about driving the engine at the sweet spot in order to maximize economy. How much of that is just the nature of the platform and how much of it can be altered depending on how you build it? If you could move that sweet spot from (hypothetical numbers here, don't panic) say 2600 down to 2100 that should also drop fuel consumption. Is this something you can engineer or do you have to change platforms (engine size)?
There are some obvious questions. Why do this instead of change engines? Well, I have a couple answers to that. Because I can. Because I feel the engine is the soul of the truck and I don't really want to transplant it. Because this sounds like a great project for my son and I to work on together. Would I consider an engine change? Yes, but it isn't my first choice. My ultimate goal is a fuel efficient truck that can still handle the occasional load. I would like to do that with the existing 454 but if I have to I will go with a 350. I know that the 350 is easier to configure for this but I want to see if we can get there with the 454.
Who'd like to school me first?
