Sbc305 to BBC454
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Hello! I wanted to remind you to research the rest of the driveline, to see if it's up to the extra torque. CBB's came from the factory with TH400's. Mine is a 1975 c-20. I owned a 68 chevelle and turned it into a drag race car. The engine was an LS-6 454. Beefed engine, tranny, rearend, factory ss396 car, let's go racing right? The very first pass, I puked the driveshaft out of the car, in third gear, opening up the throttle to full. I also cracked the tranny TH-400, from side to side where it flares up to the mounts...the bell housing part. I still ran a 1/4 mi. time of 13:70, coasting through the lights on the side of the track....So make sure the entire driveline is up to the engine swap. Regards!
Yeah, I was thinking just that. I mean it's not going to be a race truck but, might run it down the track a time or two just to see what she runs. That won't be for a while tho. Gotta say high 13s coasting the end is much faster than mine will be. Lol. Love me some chevelle too!
82sbshortbed
Fuckemall!!
SE Texas
Doug
I noticed last night that the fuel pump on the 454 only has 2 lines an input and output. My 305 has a 3 line pump. Input,return and output. So do I need to buy a 3 line pump to replace the 2 line pump on the 454? Or can I just plug the return line on the truck? Will that cause issues? Just something I was thinking about last night.
You can just plug the return hose or remove it entirely.
Hugeroost
Kyle
Someone actually paid you to haul away your scrap... good deal!
hey there are still some guys out there that think you can take a 305 and bore it and make it a 350 lol
BigBlue85
Tennessee
Joe
K10 Silverado
Allow me to resurrect this thread, I am about to perform the same swap on my truck, except mine has the 700r4.
seanhatesregister
