heviarti
- Nov 15, 2014
- Emmett, Idaho
- Buck
- C25
- 383 Stroker
So, I have been stuck with a 1979 GMC. Among its foibles is a screwy power steering pump. It whines, it leaks, when you take a turn it feels like you are driving over sagebrush, and the inside of the reservoir is rusty. obviously the solution to this is to replace it, but what I don't have is $58. Enter the 1994 chevy parts truck my work bought. They are both saginaw 'teardrop' style pumps, though the rotation on the '94 is slightly different. I have been told that the pump itself will change into the reservoir, and I have a previous pump that was removed from the truck because it was 'torn off' after the truck ran through a fence with the previous owner's drunk friend at the wheel. Other than the little molded return tube being bent, it seems fine. what I don't understand is how the pump unit can be universal if the return line is in different spots. At least with the tractor hydraulics i am familiar with, that doesn't make sense.
any help is appreciated.
