S10 and G body brakes
So just seperate the ball joints, and the rod end, undo the brake hose and grab everything that falls to the ground,Spindles same height and same bal joints so just pop it right in?
Thanks for the help.
Yep, just drop the whole shebang and take it all.
@bucket thank you that got me pointed in the right direction, then by searching with the info you gave me I found all the info I need, dirt simple 1998-05 2wd blazer. It's 2 piston slightly larger rotors and as bucket said grab the knuckle and all and a straight bolt in. Thank you everyone.
MartinK5
