Rust covertors
4WDKC
Southern Florida
Kacy
covertor m (plural covertori)
1. bedspread, coverlet
Are you serious? Stop messin' with my head!
Try using Evapo-Rust. I get great results.
all depends on where you look, pick your poison.
Snoots
Roger
Jimmy Sierra
350 w/203
4cc's of Ketamine please.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Covertor, converter, two different words sir.
You'll be ok...
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Fortunately there are some democrats converting to Republican
Camar068
Kentucky
10 yrs Air Force
is it green? think I have some of that at home. Do you rinse it off before paint/primer?
yes it's green. Typically in qts and gallon jugs. Yes naval jelly is a remover not a converter. Main thing I used it for was removing surface rust off the old Cragars.
Camar068
Kentucky
10 yrs Air Force
Coverters = Converters in the common sense world
it's called a typo! Gotta Raz Ya lol.
Billy
Dalton Ga
Billy
I’ve been using this phosphoric acid stuff from Home Depot. It’s only $15 a gallon. Turns rust quick. You still have to follow up with some sort of paint within 48 hours.
this^^^
4WDKC
Southern Florida
Kacy
Didn't even realize i did that till just now.
80cubes
US
Joseph
R2500
Fluid Film
Sent from my SM-N920T using Tapatalk
DanMcG
Central NY
k10 k10
we use ospho at work and I bought some for home as well, had decent result with rustolium as well.
I second the Ospho. It will protect bare metal for months out in the elements
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
This was the best stuff I'd ever seen but you cant find it anymore. You had to use gloves or it would burn your skin which might be why you cant find it anymore lol. Went on clear, converted rust to zinc oxide.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
The active ingredient in that was Phosphoric Acid, you can still buy the straight stuff at most hardwares.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Getting rust removers confused with rust converters...
8888
Troy Ohio
Joe
Suburban
I can say that Rust Bullet doesn't work for squat. I renamed it Rust BS. Had good luck with rattle can Extend, will check out the ospho.
PapaD
