Running rich after pump change
Nick87
Tucson,AZ
Nick
Crew cab v30
Hey fellas, I’m new to the asking for help bit, but I need some. I have a 1987 crew cab v30. It’s actually the forest service truck out of dauntes peak, the one that drove through lava.
I got it running right and got it legal and insured. Drove it for a few months and it started having fuel problems. I have only been using the passenger side tank and the drivers side is disconnected. The pump would cut out as it got warm so I swapped it out and made sure my lines on my sending unit were in there correct orientation. Now the truck would idle fine and before the pump swap. While doing the swap I pulled the tank and cleaned it out. I started the truck after the swap and it couldn’t be richer. Folks, i don’t know if anyone on here as flooded a TBI motor but I have. It ran so rich it had the whole neighborhood smoked out in a matter of minutes. I thought it could be the wrong pump pushing to much pressure, not that, I thought it could be the diaphragm in the tbi that regulates the fuel pressure, rebuilt the tbi and no result. Swapped a few sensors, checked timing, checked injectors, swapped the damn pump again! Nothin. Still runs like ****. I’m thinking gunk or something got into the return line? Or the fuel tank valve is stuck or something. I’ve been racking my brain for a month and a half. Any help or ideas would be so appreciated!
~Nick
What's the spray pattern of both injectors look like?
Nick87
Tucson,AZ
Nick
Crew cab v30
The pattern is good, solid cones and good misting but pulsing crazy fast. The pulse with is crazy. I checked the o2 and made sure it was working and traced it back to the cpu mad it’s good along with some other sensors
Also, thanks for having me here. I really appreciate the help
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
What brand of pump did you use, and would you happen to have the PN anywhere? What was the pressure reading? Was one of the sensors you swapped the CTS? Have you checked spark quality and plug quality to make sure there’s not a weak spark (coil) or worn plugs in the picture? And no codes 13 or 45 if it’s running that rich? Hmm. Unless deductive reasoning can knock this out, I’d be thinking about making a diagnostic cable and downloading the software to interface with the ECM using your laptop or buying a pre-made cable to do the same thing. The former costs about six dollars, and the latter costs sixty. That would also show you injector duty cycle to answer your concerns about pulse.
Yeah, how about the CTS? If those fail, they can make the engine run extremely rich. They can suddenly fail to, with no warning.
Nick87
Tucson,AZ
Nick
Crew cab v30
I did swap the coolant temp sensor and checked my grounds and made new contact on each. It ran the same, full rich. I don’t have the part number of hand but it’s the standard tbi pump. It’s the Delphi one. I had already put in new plugs. It could probably use wires and a coil but it has a new cap and rotor. The issue occurred right after I swapped the pump. I haven’t taken a fuel pressure reading yet. I’m not sure of the best way of going about that.
73c20jim
Tombstone, AZ
Sometimes new plugs can be quickly fouled by too much gas.
350 w/203
Fuel Pressure Regulator?
EGR (sometimes)
Vacuum leak?
MAP sensor?
Mine had a bad Intake Air Temp Sensor. ('88)
It's really best to get a scanner.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I will say that vacuum leaks are going to hurt you. Especially if you’re leaning the engine out, and then the computer says dump more fuel. The EGR is a very unlikely culprit at idle, but on the road, its potential to hurt you is very prevalent if it’s not working right. @Snoots, the OP did mention replacing the regulator diaphragm, but I’d say the MAP sensor is up there in its potential to mess you up. There is a vacuum test you can do by getting a Mityvac, pumping up the sensor, and checking voltages, but I’ve never done it. I just hook up my laptop to see what all the sensors are saying. Mine is generally very quick about telling me when there’s a problem. If you’re interested in the homemade scanner, Georgeb wrote an excellent post on how to set it up, and it’s a sticky in the TBI section.
Nick87
Tucson,AZ
Nick
Crew cab v30
I’ll take a look at a few of those things. I checked the Egr and made sure it’s good and it is, I checked a few other things but I’m thinking about just finding a scan tool. That would help
Nick87
Tucson,AZ
Nick
Crew cab v30
The part number on the pump is fe0115
chengny
Check for leakage through the injectors when off stroke. Simple test, just unplug the injector connectors and crank the motor. Obviously, there should be no fuel spraying/dripping from the injectors.
Another sensor that the ECM relies upon to calculate required injection duration is the TPS. If the TPS is indicating that the throttle is being opened, the ECM will crank up the fuel/air ratio. The only codes associated with the TPS are 21 (a short in the circuit) and 22 (an open in the circuit). However, if it is just providing screwy outputs no DTC will be thrown.
Nick87
Tucson,AZ
Nick
Crew cab v30
Thanks a bunch! I’ll look in the morning
Nick87
Tucson,AZ
Nick
Crew cab v30
Hi folks! I wanted to say thank you to all that gave me a hand in finding my problem on my crew. I found the problem! The fuel switch valve was stuck and not letting the return line feed through back into the tank. Therefore pressurizing the line and feeding into the motor with no where else to go. I did a series of tests and found that conclusion. It’s purring like a kitten now. I’m going to bypass the valve all together because I’m only running the auxiliary tank at the moment. I’m the future I plan on mounting a suburban or blazer tank (32 gal) tank so I have very little problems with two sets of everything as far as pumps and tanks go. Has anyone here done something like that? Let me know!
Thanks again!
jlyon1006
