buddy350
- Sep 13, 2017
- El Paso,TX
- Buddy
- 1973 k20
- Suburban
Just finished a 8 point roll cage and have been looking for some roll bar padding to put in areas around the driver.
Last time I built a cage was about 17 years ago and I seem to remember we always just used round foam padding with 1 3/4 inch center diameter.
Now all that seems to be out there for roll bar padding is what is called "offset".
I went ahead and purchased some offset padding only because I could not find just normal round padding anywhere and sure enough when I installed some of it I noticed right away it had a tendency to twist so that the thin side would turn towards the driver and the thick padded side would turn away from the driver.
That's a serious danger if a driver is out on the track and the padding were to twist or turn in the event of a accident the driver would be exposed to the thin side of the padding
This would not happen if the padding was a equal diameter all of the way around.
For the life of me I cannot understand why offset roll bar padding is the standard these days, just makes no sense.
I understand that padding should be fire resistant and so on and that could all still be achieved with equal diameter roll bar padding.
Anyone have any input on this matter?
