Rocker Panel Repair/Replacement
Damn dude, your'e diesel.
I'm good at drywall mudding and bedding, just slow and neat about it. So I don't do it for a living, but I sure do my own. Whenever I move or buy a new house, first thing I do is gut the garage. Take all drywall off. Run power outltes, every 4 feet at workbench height, an outlet up high where a TV Shelf is built, Cable is brought in, phone jacks brought in, 220 outlets for compressor and welder installed, insulate with R13, then rehang drywall, tape, bed and texture. Hang Flourescent lighting at all 4 corners of the garage, shoot cellulose insualtion 12 inches deep in the attic, then purchase insulated garge doors at a later date. The good kind, double walled filled with foam like a referigerator door, not styrafoam with vinyl backing. Then usually add a vent or 2 from the CH&A depending on how big the unit is for the house with duct diverters if needed. Haven't insualted the door here at this house, and haven't added the heat and air vents yet either.
If you're good with drywall mudding you'd be good at body work too :waytogo:
When I say I did commercial drywall before, I didn't tape, mud and finish. I was the guy who did the metal stud framing and hanging it. Then the finishers came in behind me. But, I seen enough of the finishers doing it, I know how to do. Just never did it to where I had to be fast at it, and I don't like a big mess to clean up, so I am slow at it. I have done a little body work too, but also very slow. I am not one to do many tedious things. I like to rock and roll and see progress quickly for me efforts, so body work and drywall finishing are not think I like to do. I can sure paint though. That doesn't bother me a bit. I get to see instant gratification, so that I can just fine and agian, not very fast, but I do it right.
It's actually better if you're slow at body work. I'm a naturally impatient person and found that if I didn't slow myself down and take my time I'd have to go back and redo things anyway so I might as well take my time.
Thats kinda what I am saying about myself. To aggresive and high strung, so I don't like doing that kinda work. I will do it though. I look forward to get my mind made up on my projects, getting them consolidated into trucks, then get to start making one of them nice looking.
i'm a naturally impatient person and found that if i didn't slow myself down and take my time i'd have to go back and redo things anyway so i might as well take my time.
x 2
:waytogo: You'll probably end up finding it relaxing once you get into it and according to you as obsessed (not sure you've used that exact word :shrug:) as you get when you get focused on something the body work will probably turn out pretty awesome cuz you'll pay close attention to the detail and making sure everything is perfect before spraying any paint on it....
You are probably right. I've been told many times I am a perfectionist, which is likely true, and also why I tend to avoid body work. If I can't get it perfect or done right, it woudl just frustrate the hell outta me. I am about that way with just about everything I do. I do it right, or don't bother. And if someone wants me to do a job for them and they want cheap, then I tell them I'm not your guy. If its gonna have my name on it, I am not skimping. Who knows, if I ever did get into the body work and settled down and got to enjoy it, I just might be dangerous with bondo, a sawzall and a tack welder. :roflbow:
blue900
