Rim swap from 1985 to 1992?
vinturbo71
NYC
Vinnie
Yukon
5.7L
Will 6 lug rims from a 1985 1500 fit on a 1992 Tahoe with the six lug bolt pattern?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The lug pattern will fit. But the center bore may not. Depends on the wheels.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Brake calipers may not clear the older wheels.
They should, this is a 14b SF that a friend and myself built for his blazer, homemade disc brake brackets I came up with using gmt400 K1500 front rotors and calipers. The wheels on it are 15x10 US Mag slot mags. No hitting or rubbing.
I've seen a lot of 6-lug rallies and factory aluminum wheels from squarebody trucks used on the '88-'98 trucks over the years.
dannyphx
