replacement radio
john55
illinois
john
my radio in my 77 c20 doesn't work am/fm/cassette pioneer it looks stock ? what type/years radio will fit my truck without cutting the dash panel or would it be easier to cut the panel to fit modern radio? thanks in advance john
85K10
Florida
James
I have been debating this issue. I want a new radio and hate to cut the dash. Not many options for radios tho to go back in the stock location. What To Do.....
Driver4r
Nebraska
Trevor
k10,c20
i cut mine, but i also have a spare truck to cut the radio slot out to patch mine if i need.
If it looks stock, it must be really old. My '79 came with an ancient looking AM/FM Cassette that didn't work right and the tuner scroll thing had come apart inside. I was able to take it apart, figure out what's wrong, fix it, bench test it, put it back together and install it... and I know squat about electronics. That old radio was very mechanical.
john55
illinois
john
i 'll pull it out and see if it can be saved. i would rather not cut the dash if possible
john55
illinois
john
i got it to work on am it needs a antenna has the windshield built in and the cable is broke where is the best place to mount a exterior antenna?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
1988-91s had them on the right fender stock.
I still think FTW, Jake Wells had the best idea for stereo's. One downfall to it, NO STATION PRESETS. That doesn't bother me though. I have 2 stations I listen to locally. But for $35, you'd hope a thief isn't interested in it. It has pre outs for an amp, and it has a Jack for listening to your MP3 player. Cheap and very effective. Add your hidden amp, and listen to all your favorite music on your MP3, not have to butcher your dash, little fear of it being stolen and only $35. How can you go wrong???
That's good to know info too. I"m wanting to do away with windshield antenna I think and I was wondering where a good place to put it would be. I'd rather use an OE spot. I might even look for an OE antenna off a later model Burb next time I got to PullAPart.
It's also the same antenna used on the Celebrity and 6000.
I have no gripes with the windshield antenna, they seem to work well even if the window is cracked right through it.
J Knight
Baytown TX
82 Chevy
350ci
I would get a small rubber antenna($9) and stick it under the dash till you get a widshield antenna.
john55
illinois
john
thanks for the ideas i'm going w/the $35 radio and under dash ant until i replace the windshield it's cracked
RetroC10Sport
Jay
pontiac aztek
And then grab the wind buffeting mast off a 1995+ S10.
jimlayhee
