Replacement Bed Question
Splandman
Crescent, OK
Scott
I have this 1975 3/4 that has a pretty rough bed and tailgate on it. I am not sure that the bed would be smart to try to save. I am no body expert but it looks like it would add a ton to paint and body even if it's possible to be straightened out.
I have not decided if I am going to put a flat bed on it or look for a replacement long bed. If I do go with a replacement are there any differences in 73-87 beds or do I need to look for an early version to keep the truck looking correct?
Splandman
Crescent, OK
Scott
I just saw a post from JKnight in another thread that seems to explain it somewhat.
all are the same with the exception of the filler door area. The early ones the cap just stuck out there so there was no door. The later ones had the square door so that's the main differences externally. The lines are all the same.
Splandman
Crescent, OK
Scott
OK, thanks. This one does not have a filler door, but I don't guess it would be the end of the world if I find a decent bed that has the filler doors.
firebane
Calgary, AB
Curtis
Don't forget the square door boxes will use different filler hoses as well.
J Knight
Baytown TX
82 Chevy
350ci
73-78 have fuel cap
79-87 have fuel doors
79-83 have sheet metal fuel filler neck mount
84-87 have plastic fuel filler mount
73-80 single tanks on right side
81-87 have single tanks on left
73-80 have large tailgate mount trunions
81-87 have small tailgate mount trunions
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
If you get a wild idea about building a bed from new parts I may be of some assistance.
Sent from my iPad using Tapatalk
We're talking about a short bed here right? Ehhh, short wheelbase chassis just don't look all that great with flat beds. Now if it were a 4x4 and wanted the truggy look and a bed was made of angle iron, iron mesh and roll cage type, then they look OK, but doesn't sound like that's the purpose of this vehicle. So IMO, if it matters, I'd be looking for a way for a good bed.
So what is rough about your current bed? Bedsides, Floor, Tailgate or what? Maybe you can get by by just replacing a couple panels with aftermarket cheap China sheetmetal. You can always put a good finish on it so it will hold up well.
Splandman
Crescent, OK
Scott
I didn't even think about building one, was just hoping to find a decent one in good shape.
Splandman
Crescent, OK
Scott
No, this one is a long bed. It's a 1975 4X4 3/4 ton camper special. The tailgate on this one is not repairable (I think) kind of looks like someone just beat the hell out of the top edge. The top of the bed rails on both sides are also pretty beat up. Also looks like someone maybe ran over a stump or big rock because the bottom of drivers side is smashed upwards.
I do have a short bed 2wd that probably needs a bed too, it has different problems, mainly rust over and behind wheel wells and then the rear of the bed floor looks like someone repaired it and did and awful job. I think I could chip the floor away with a screw driver. There was a very nice short bed on craigslist, it was $650 though. Couldn't make myself buy it but I am guessing the one I have would be that much in work at least.
There are some pictures of the long bed in this thread
http://www.gmsquarebody.com/forum/showthread.php?t=12792
but I swear it looks way better in those pics than it does up close. In fact when I went to buy it I was really disappointed but when I drove it I thought it did pretty good. Its a big block and was running good and shifting smooth so I bought it.
Don5
West Virginia
Don
k15
I like that green truck. I saw a pic of a really shiny clean one on another web site. It was really sharp.
Splandman
Crescent, OK
Scott
I like it too, there are a few spots where you can see what the paint is supposed to look like. The longer I have the truck, the more I would like it to be my driver. Going to be a lot of work though.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
A lot of work, but in the end it will be well worth it.:headbang:
ESONE
