Recommend Me a Reliable/Budget Serpentine Kit
HUFFINCOSMOLINE
One Gas Station Town
N.
C-10
Might oughta consider a 79 truck is gonna all be standard thread. You'll have to source the steering lines and new bolts. You oughta be running a 7 blade fan already, no?
What cylinder heads u got?
Anything cool?
Not sure about the smog pump but thats easy to delete
Yes 7 blade I believe. It has factory heads with what sounds like a mild cam. I’ve not been through the motor. A set of tricked out heads would be nice.
The accessory drive from a 4.3 V6 is the same as a V8. You will want a water pump from a '93 truck, just as a year example.
Scott91370
Burleson, Tx
Scott
Sierra1500
I bought this one. I was wrong about the price (edited), It is only slightly higher now than when I bought it.
Mine has the factory style power steering pump with attached reservoir.
34Chevycp
