Recommend a distributor
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
About 18mos ago I installed an Edelbrock TBI intake manifold. I'd previously had a problem with the original distributor "chirping/squeaking" and rust around the base of the rotor, etc. I'd pumped some Triflow into it, and that seemed to take care of that issue, but the engine had always had a slightly rough idle and I'd read via a GM tech, that cracks around the rotors were a common cause.
Figured that since I had it all torn down, I'd replace the distributor. Purchase a rebuilt unit at NAPA and turned in my original as a core (stupid, I know).
About 6mos ago, the engine died driving through a parking lot and wouldn't restart. I popped the air cleaner off and laid hands on all the electrical connectors, and then it started and ran fine. It did it again a few weeks later, and again started for no apparent reason.
Hasn't done it again, even on a couple of 5hr each-way camping trips towing the tent trailer in near triple digit heat..............until last week where it died on my wife, just driving down the street. She'd only got about 3/4mi and by the time I got there, it'd restarted and was fine. Again, fine ever since.
Talked to a GM trained tech that I respect and he immediately said, "ICM" And well, here I am, sporting some rebuilt POS from NAPA.
So, should I go with an AC-Delco unit, or with something aftermarket? I'm not big on hanging aftermarket unless it's really tried and true....and there's some actual benefit, and not just a wiz-bang bragging session.
Thanks!
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
ACDelco will be your best bet for the ICM. A lot of their parts are made in China these days, but the quality is still pretty decent, and much better than aftermarket.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Airtex/wells is best if AC Delco cant be found. Make sure you match the part number up with your old one, there are 2 different ICMs for TBI trucks, and it has to do with spark latency settings.
austinado16
Central Coast, CA
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I see I can purchase the AC-Delco ICM by itself, at SummitRacing, for $72http://www.summitracing.com/parts/acf-19179578/overview/make/chevrolet/year/1990/model/v1500-suburban
Not sure what my original ICM's number was, and it's long gone. I appears this AC-Delco unit substitutes for quite a few different ones.
Just ordered the AC-Delco unit locally for $69. Be here tomorrow.
Thanks guys!
Sure thing! You might try checking RockAuto.com next time. Looks like they have the ICM for $52 or so. Depending on shipping and how patient you are, you can sometimes get pretty good deals.
austinado16
Central Coast, CA
The one I ordered from the local AC-Delco supplier wound up showing up today, so it's installed. Hopefully the ICM was the issue and I can go back to trusting the 'burb as being bulletproof and 110% reliable, which is what it's always been.
Jims86
Patterson,Ca
5.7 TBI
The one I ordered from the local AC-Delco supplier wound up showing up today, so it's installed. Hopefully the ICM was the issue and I can go back to trusting the 'burb as being bulletproof and 110% reliable...which is what it's always been.
I wish the wife thought that of my Burb...it would have been fixed by now.
austinado16
Central Coast, CA
The wife loves it. It'd be her DD if fuel wasn't $4-$5/gallon all these years.
It's always been very reliable, but ever-present in my mind is the fact that the original 5.7 has 286k on it now, and of course, the survival of the 700R4. Most of what it does is either long distance road trips, or really long distance towing.
goodwrenchca
