ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
Some may have seen or read about my project, but if you haven’t, here’s the rundown.
355ci SBC, flat top pistons (w/ 4 valve reliefs), 64cc camelhump heads. Performer RPM intake, long tube headers. Cam is unknown- haven’t been able to get it to run good enough to see if it has a lope. Brand new rebuild.
I bought it mid-swap, and now want to get it running…right.
Before I go buying a rebuild kit for the carb, should I be looking at a 650 instead? It has a flooding problem even with a 5-6psi Edelbrock fuel pump.
If it has a stock or mild cam, I will likely do a mild street cam like a Comp Cam XE268.
If it were you would you go with a 650 now or just go through and rebuild the 1406 at this point? Thanks in advance.
