Rear wheelhouses for 1991 suburban square body
carsenretka
MN
carsen
Suburban
I was able to go on Brothers trucks and it said that these were applicable to the suburban even though it doesn’t mention it in the description. However, it says it when you go down to applications and apply the filters. I’m sure they are the same or similar as the ones on LMC and that they will require some fabrication.
While it may show that they are correct for a Suburban, they are not. Suburbans have different wheel housings. Using pickup/K5 parts requires modification and other things that could be an issue that will need dealt with. Like carpet fitment. Or buildup of road debris due to the design of the pickup outer wheelhouse. You will need access to the lower quarter panels for cleaning out the debris. Pickup and K5's don't have the lower bed sides sealed off.
unimogguy
