84GMCSierra
- Feb 26, 2023
- Central Arizona
- Paul
- C2500
Good Morning, or afternoon, wherever you are. I have an 84 GMC Sierra C2500 base model, and I need to replace the 16 studs in the rear axles due to them being slightly stripped(Very hard to remove and install). Anyways, my question is do I need to remove the axles to replace them? If so, no biggie as I have a slight gasket leak in the cover so will replace that and the gear oil at the same time. Thanks for any help and/or tips
