Rear Main Seal
Mango
JacksonWyoming
Gil
@newguy11 I am planing on inspecting that again With a camera, If its the culprit off comes the intake and better RTV Ultra Black!!!
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
Rear china wall leak on the block is my guess.
Plenty of people have put in their 02 cents,here's mine If you just did the intake that's where I'd double and triple check. And the intake can leak oil and not leak vacuum. If you determine it's the rear seal on a 1pc seal 2wd it's no big deal at all . As for the stop leak the way I understand it it is an additive that makes rubber swell that's how it creates a seal but now you've compromised everything rubber that it touches,not how I'd do it . Get 2 long starter bolts take out 2 bell housing bolts and replace them with long starter bolts. Undue everything like you were going to pull the transmission, pry the drive shaft loose at the rearend, tape around the ujoint to keep the caps in place.slide the transmission back on the long bolts and you will have a window big enough to pull the flexplate out through the bottom. Then you can access your seal and end plate.
That would have been good info in post 1. Because we don't all know what everybody has and could Give bad information. Like assumed 2wd,but had I not written 2wd in my post you might have tried following my advice.
Mango
JacksonWyoming
Gil
Done no more leak replaced the intake manifold gasket and used ultra black RTV bigger bead set it in place tightened the bolts until it spouged out of the china wall let it sit fore an hour then torqued it to specs 30 ft lbs then to 35 ft lbs this may be it??!!
Mango
JacksonWyoming
Gil
Hey thanks for the Replies
The intake Seal has stopped Now checking again
Update: just notices small oil on the ground. oil on the bottom of the bell housing Pulled it off to inspect, Yep oil in the bell housing and wet in front of the oil pan, No oil on the flex plate? Cleaned every thoroughly with cleaner and hot water, Reassembled and added dye to the oil drove for 10 miles no leak on ground and no visible leak no dye detected yet ?? Could it be Oil pan gasket, Rear Main Seal, Valve covers? Time will tell:oops:
Seserge
