davbell22602
- Jan 16, 2011
- Bunker Hill, WV
- David
- I Dont
- Have
- One
So this past week I been replacing my first rear main on my 97 K1500. I went to GM dealer so we could borrow the J-35621 tool that is needed to do the rear main installation. The tool costs $130 unless you get a used one for around $50 on ebay. Also replacing the oil pan gasket while everything is apart. All data is over rated. All data says to just loosen the oil pan bolts and it comes right out, wrong. The chilton online library says to loosen some of the front axle bolts to move the oil pan out of the way. Well I followed the all data removal steps for the oil pan. After I got the bolts out find out that front axle has to be out of the way enough to drop the oil pan because the oil pan wont come out and hits the front axle. Were gonna try to feed the pan gasket through the oil pan without unbolting the front axle tomorrow.
Here's pics of the oil leak
