Rear flip issues
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You really want to have SOME droop travel - without it, it will ride and handle awful.[/QUOTE]
Important point.
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
Thought about this too... but eveything i read says to put the offset hole towards the front of truck
You're right - my bad. The axle has to move back, because the leafs are angled. You done good.
I'm thinking the wrong shocks. Did you peel off a sticker and find a Monroe name a part number?
Cotas86
Phoenix
Anthony
No didnt get a chance yet... gonna call crown suspension (where i purchased kit from) and see what they have to say....but probably just going to go with longer shocks
Cotas86
Phoenix
Anthony
Important point.[/QUOTE]
What exactly is droop travel?
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
Droop is when you jack the truck up, and the suspension hangs down. The amount it hangs down (droops) is called "droop."
You ideally want enough droop that no matter how hard you drive, all four wheels are still on the ground. Sometimes that's hard to achieve.
When I design a suspension for handling, I like to shoot for about 66% travel in bump, and 33% travel in droop. Not hard and fast rules, as usually there are component and packaging limitations. Even if your bump and droop were 50/50, that would be just fine.
If you had NO droop travel, every bump would you have you airborn.
Jerry phillion
Saginaw, mi.
R10
Jerry phillion
Saginaw, mi.
R10
What happens when you remove both shocks? Does truck
Sit same on both sides? Does suspension work as it should ? If it does, then it's a shock problem. If not, Recheck your installation again. Also, check your wheelbase dimensions. One side may be longer than other side. Just my .02.
malibuman402
nc
Larry
C10 Silverado
BB 402+.060 = 413.8CI
correct me if im wrong, but it looks like the overload spring is still in the spring stack on the right side. 5 leafs instead of 4.
Cotas86
Phoenix
Anthony
No you are correct, i took the pictures after the first time i put everything together when i was looking to make sure i installed everything correctly i went ahead and pretty much dissasembled what i did to be 100% everything was correct i figured id remove overload leaf while it was taken apart for second time
Cotas86
Phoenix
Anthony
Truck was sitting level when it was on ground. Driver side works as it should while passanger side (where problem is) is stiff no give at all in shock. Triple checked installation also measured from end of frame to center of axle and was within 16th of an inch of one another.
87scotty
Central il
Andrew
V20
5.7 for now
Why not move shock mounts to make them mpre verticle and they woudnt need to be longer
74brik
Cherry Point MCAS
350 SBC
Had this same issue with crown suspension. The shocks are Monroe with their stickers on them. Their customer service is a joke too. Your best bet is to just get your shocks elsewhere which defeats the purpose of spending less money on their kit
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
X2 yep...Crown doesn't make shocks...and neither does Mcgaughy...obviously and Crown doesn't sell the correct length with their kits either. Don't bother buying the overpriced "drop shocks" either. Stock shocks work fine (gas charged) and move the mounts and install and extension piece on the rear shocks.
smoothandlow84
Steve
Remove BOTH shocks then check truck height and suspension travel with shocks OFF.
Im thinking its the shocks binding due to improper length of one or both
smoothandlow84
Steve
Your passenger side upper shock mount may be the issue as well
jlyon1006
