Rear end swap, new leafs, and flip kit = shocks hitting frame
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
Just finished swapping a 12bolt into my '88 Burb R10, put a full leaf pack (in place of a dearched set of 3) and flip kit. Now, I'm noticing that the rear shocks, Belltech 2208HF, are hitting the frame. It actually rides great and you don't notice an issue until you take off from a stop, you hear a clunk.
Any ideas?
Sent from my SM-N986U1 using Tapatalk
Poppy 87
Bloomingdale GA
R10 Silverado
Just a wild ass guess, but doesn't axle flip drop require shock extenders?
radio2000
South Carolina
83 and 88
I think so, but I'm using drop shocks, so it's my understanding that they're not needed.
I made some adjustments the rear end tonight and it seems to be a lot better. Plan on putting some more miles on it tomorrow and see it does.
Scott91370
Burleson, Tx
Scott
Sierra1500
Nope. I did it on mine and there is plenty or room. The extenders are used to keep the same shock angle for better ride.
radio2000
South Carolina
83 and 88
Ok... Update. Looking for advice
The burb has been riding pretty good, but I noticed the other day that the rear end is sitting too far forward (wheels not centered in the wheel well). So after some research, I realized that the block that came with flip kit was turned around backwards hope for center spring bolt was towards the rear of the burb. Tonight, I turned them around, wheels much closer to center of the the wheel wells. However, now the rear bounces like crazy (think old lincoln with busted air bags). The driver side shock, looks to be at the correct, or close to the correct angle, but the passenger shock looks like it's laid down more (like the rear end needs to come forward on that side). I'm at loss, any advice other than rolling the damn thing in a pond.
hedgeapple51
Hutchinson
Larry
83'
C-10
Is one of your springs sets on backwards? Some springs are not Centered.
Sent from my 100005206 using Tapatalk
RoryH19
Rory
R10 Silverado SWB
No advice on the springs/blocks but did you have to use a different u-joint when you swapped the 12 bolt for the 10?
radio2000
South Carolina
83 and 88
I wondered that myself, but they look to be set the same way. Longer side forward
radio2000
South Carolina
83 and 88
Yes sir, I did.
RoryH19
Rory
R10 Silverado SWB
Yes sir, I did.
I thought the yoke may be different. Do you remember the part number of the u-joint?
radio2000
South Carolina
83 and 88
I bought a new yoke and u-joint. I'll try and find the receipt from the shop when I get off
radio2000
South Carolina
83 and 88
Update... Now struggling with shock extenders. Come to find out, the rear end must be out of a 4x4 and had different shock mounts... Who knew. Any ideas for shock extenders that will fit?
Same problem almost 10yrs ago... http://67-72chevytrucks.com/vb...read.php?p=8824206#post8824206
radio2000
South Carolina
83 and 88
Ended up having a local shop work on this for me and this is what they came up with.
Next step, c-notch...
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
same here! extended bracket fix the problem! :)
brentjo
