MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
The ones I used in my 10 bolt K10 are Napa 534G made by Federal Mogul, they heavy duty greasable joints. They honestly are the best IMO
Another thing is when you install the rear drive shaft u joint into the pinion yoke its not a bad idea to install the c clips onto the caps that are accepted by the pinion yoke. The reason being is that the stop tabs on the pinion yoke that keep the caps from sliding side to side can be worn allowing a little bit of side to side movement which will destroy your new joint in short order. Putting the c clips on the caps keeps the joint from moving should there be any wear on the stops. It works really well too if you already have worn out stops. And it will prevent the stops from wearing.
