Rear Diff Carrier
Arkansas
Cody
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Backlash looks good at 0.006" but it looks like it has too much toe pattern, pinion needs a little more shim. Of course adding as little as 0.010" on the pinion will likely change your side shims.
crazy4offroad
K-10
350/SM465/NP205
edit: looked at your page 1 posts, the difference in drive and coast pattern sometimes can't be corrected but if you can get it closer to the same you'll have less noise on deceleration. Adding pinion shim will make your current backlash tighter, or too tight. Before changing the pinion shim try moving 0.005 from the left to the right, basically opening up your backlash a little. 0.004-0.012 is acceptable for new gears. It may help with the difference between your drive/coast patterns, since currently they look pretty deep in the root of the ring gear.
DawgmanDew
