fast 99
- Dec 31, 2021
- Spokane, Washington
- Brian
- K20
First need flush fluid. Disconnect compressor, remove orifice tube. I don't measure the fluid. Just pour a cup or so in condenser and evaporator, using air hose blow it out. Do not use full pressure, especially on evaporator. Put a rag over the other outlet to avoid a mess and check for contaminates. Repeat until clean, flush hoses., replace drier. Remember there will not be any oil in the system at this point except compressor if that was re-used. Going this far recommend replacing the hoses and of course add correct AC oil spread throughout system.
