Rattle in oil pan below 700rpms
usar17
PA
K20 Silverado
TBI350/700r4/NP208
I bought a new flexplate and bolts anyway since its apart. Putting it back together today
Sent from my SM-G950U using Tapatalk
usar17
PA
K20 Silverado
TBI350/700r4/NP208
All bolted back up. No more noise. Damn flexplate bolts
CSFJ
Did you happen to loctite them this time?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Yes i did! And had a nice talk with my friend that assembled them last
CSFJ
Lol. Reason I asked about the loctite, back when I was into jeeps, a buddy had dropped the trans on his, and ran into the same issue. Turns out, the 4 cylinder models required loctite, but not the six cyl. Guess they figured the 4 rattled more.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
New issue I found. After road testing with the new flywheel I have a shake while the torque converters locked. What would have caused this. What did I put back on wrong
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Trans bolts torqued to spec? Everything lined up ok? Driveshaft misaligned somehow? You didn't have to mess with too much to replace the plate...
or trans mount not tight?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
No it was a fairly easy swap out. Nothing is shaking in idle. Its only when the torque convert locks up
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Yeah, that registered after I posted. I can't think of anything in particular with those exact symptoms. I just started throwing out ideas. The only other thing that comes to mind is the flexplate & its weights. But I'd think you'd feel it in the lower RPM too.
Or the torque converter itself... But you've had it up to lockup before, right? Never any issues until this flexplate issue?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Any thoughts that i somehow have tcc shudder now? No clue why
Where did the flexplate come from? I'd guess it is not balanced quite right and it becomes evident when the converter is locked. Lower rpm and higher load might be creating the perfect storm.
MrMarty51
Eastern Montana
Martin
If the flex plate was out of balance, I believe that You would have vibration in park or neutral when the engine is revved.
No idea other wise except if the clutch in the TC is slipping.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Was a cheap autozone pioneer flexplate. But i swapped a good one in and still have the issue
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Maybe look at some other components, such as the carrier bearing for driveshaft (if applicable), trans mount, etc. It is very possible that something else just happened to go bad at the same time. Could it be possible that it just feels like it's happening at lockup and not directly related to speed? Not that I'm doubting you, just stranger things have happened.
Like for example, unbalanced tires can have a vibration "sweetspot" at 40 -45mph, where it's most pronounced. You may hardly feel it under or over the "sweetspot" mph.
Just to be clear, you're on the 3rd flexplate then? The 1st original with the rattle, the 2nd where the rattle was corrected, and now a 3rd to replace the AZ cheapy?
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Yes 3rd
Gators01
