Milblazer
- Mar 21, 2013
- Colorado
- MilBlazer
- K5
Here is some stuff that is taking up space and needs to go. From left to right:
New gates 6.2 upper hose w/ less than 100 miles on it
Stock wiper arms off of an 84 K5
Engine compartment plastic mount for factory bottle jack
Shield for dual tank pump
Ashtray
Pickup cab corner speaker mounts and covers
Automatic shift lever
I just want to get rid of the stuff above so if you pay for the ride it is yours!
I also have a rear heater unit out of a suburban that I have cleaned up. Comes with the heater core unit and fan that works, vacuum controlled coolant switch, rear heat switch and harness that is missing a bit of vacuum tubing. It makes a bit of noise at startup but will quiet down. I did take the core out and let it soak in some CLR to clean out any build up. The plastic case has a leg that was glued back on. Make me an offer on this.
I do have another rear heater with no harness that needs put back together that I need to get rid of too. It is in the box in the attached pictures. Make an offer!
Ashtray
