Radiator with twin fans
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I took the fan clutch off today, spun the bi-metallic strip round to the next hole to lock it manually. Going to see what happens next time I take it out. Hopefully it won't overheat and we'll see if the fan clutch is the culprit.
Cool tip, thanks,
Snoots
Roger
Jimmy Sierra
350 w/203
Let us know if you hear a great 'roaring' sound at highway speeds.
Well damn. That's pure genius! I have to remember that trick.
Gilderbeast
Fargo, ND
Brett
If it were me Id get a new 4 core radiator, thermostat around 195 degrees, and a new clutch fan. Seal the shroud real well. If you want electric fans Id recommend 2010+ F150 fans. They supposedly flow 6000 cfm. They installed them on the Raptors as well. Otherwise Derale makes great fans.
NZurban
Blenheim, NZ
Rich
K20 Suburban
6.2L diesel
Haven't driven too far since I did the mod with the hydraulic fan clutch but driving round town the last couple of times when I've gotten home I can here the overflow hose bubbling into the overflow container. Temp gets up to about 160, so not real warm. I'm thinking maybe a head gasket has let go and I'm getting compression gases into the coolant. Nothing showing in the oil. I'd like to pull the wagon off the road and get it sorted out. How difficult is it to lift the body off the chassis? I'd love to give the engine a light rebuild but don't fancy hauling it out the usual way. Can I lift the body off the chassis whilst leaving the engine/transmission still on the chassis?
You can, yes.
A weak radiator cap will let the coolant gurgle into the overflow bottle.
NZurban
Blenheim, NZ
Rich
K20 Suburban
6.2L diesel
Yep, I hadn't thought of that, makes sense though if the engine is not really hot enough to "boil" off that a weak radiator cap would allow some pressure to vent off to the overflow bottle. I'll swap that out and see if it makes a difference. Guess I'd need to remove the front fenders/guards to remove the body from the chassis?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You can, yes.
How many times do we check the first thing last...?
Err, we look in the last place first?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
And coming from the guy asking us why his rig is overheating...o_O
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Draw alot of amps(cheap). But i can stay under 150( gauge) in the rocks all day.
Its a huge radiator compared to what I had stock though also.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Yes the springs are backwards, but they were so weak that was the only way to get them tight.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
It would cool even better with a shroud, but obviously you don't need it.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Agreed. All I would change though is going to name brand fans.
And there is only one to invest in.... SPAL!
I have two 16" pullers for my 496 build. One is enough but I want redundancy to be sure to get home... should I want to actually return home.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Agreed. I went two because- cheap!
jlyon1006
