I didn't see a way to search other than vehicle-specific search on the site, do you carry line locks?
Also in your opinion for a mud truck I should probably only run slotted rotors right? Instead of cross-drilled?
I can find you line locks through my other suppliers, R1 supplies most of the normal brake parts like rotors, pads, lines, calipers, caliper paint, etc But when a customer wants something else aftermarket I can often find it for less through my other wholesale providers. If you have a particular brand or part number you are looking into, shoot that to me and I will find it and on about 99% of anything aftermarket I can at the VERY LEAST match any online advertised pricing. Most of the time I try to beat them though. Hit me up with particulars if you are already looking for that one type of line lock, otherwise I will take a look see and get back to you with what I find.
As for the mudder, I would assume yes just because of wanting to avoid the mud packing in the holes, but then again, it would be packed everywhere else anyway, so it may be personal choice there. I can't really say for sure if there would be more than inconvenience in cleaning running the drilled and slotted as I have not run them on a mudder.
Based on the info you've just given I think I know the route I'm going to go the next time I need to do a brake job on any of my vehicles! This brings a couple of questions.
1. For my '77, do they make a disc brake conversion kit for the rear (currently drums)?
2. For my Burb, do they do rear rotors as well?
3. For my 91 Caprice, do you all have kits for those?
Answers:
1. I am not sure, I know I have them for later GMT400 style trucks, but I will have to double check for the 77.
2. Yes, what year burb? If it has rear rotors already, we can get those from R1, if they are rear drum then I can get a kit for it through my other suppliers to upgrade the drums to discs. IF it is a non hydro boost vehicle, we also offer the SSBC Firm Feel Master Cylinder as an upgrade and I have heard some RAVE reviews on the improved braking feel in the pedal and braking response overall from that upgrade.
3. Yes, we have rotors for the front, drums for the back, rear brake shoe adjuster replacement kits, calipers, etc, etc.
