geocrasher
- Jun 14, 2018
- Northern NV
- Ryan
- V1500
The goal would be something like one of these:
The reason? I need a pickup bed for carrying fuel and supplies. Don't want to carry them inside, and don't want to carry them externally or on the roof. The questions I have are related to the body work involved. Cutting, alignment, and what not I think I can figure out, but the part I don't know is the finish work: Welding a cab back in and converting from barn doors to a pickup tailgate, and capping the bed rails. Would an inexpensive flux welder be enough to do the job, or would I need to go full MIG? And what other skills would be needed? I've done a few welding projects in the past, but all with stick. I don't think this would be a good project for a stick welder, even 3/32" rod at 30A would probably just blow holes in it
I figure on getting an old car hood, using a cutoff disk to cut long lines in it, and then learn to weld it back together without warping it, as practice, before cutting up my Burb. Are there any other skills I'd need or other considerations? Thanks for any and all advice.
As an aside, my buddy thinks I'm nuts to consider this and that I'll never finish it if I do cut it up. My own biggest concern is how to cap the bed sides. Thanks for any input!
